timrobrus Posted December 2, 2020 Share Posted December 2, 2020 Just received a new PG and the volume pedal taper is very abrupt ie goes from v quiet to v loud very suddenly at about the halfway mark. No mention of being to adjust this anywhere in the PG or PG Edit manual. Anyone know if it’s possible to adjust this? If not, can I permanently reassign the pedal to be expression for another parameter, and use an external expression pedal to control volume? On a separate note, the big volume knob has no effect when I use the Amp out jack, but works with the Main out. Is this correct? Seems silly Quote Link to comment Share on other sites More sharing options...
billyh414 Posted December 7, 2020 Share Posted December 7, 2020 In the pod go edit software, you can click on the volume pedal and adjust the taper between log/lin. You can also fine tune the overall sweep range. By default it's log and it's terrible. I usually put the vol pedal at the end of my chain as a mute and it works really well when you dial it in. Quote Link to comment Share on other sites More sharing options...
Woods6q Posted August 28, 2022 Share Posted August 28, 2022 I'm not the one who asked but I was having the same problem. Your response is very helpful to me even though I haven't tried it yet. Is anything adjusted with screwdrivers and wrenches anymore? Quote Link to comment Share on other sites More sharing options...
cain29671 Posted September 3, 2022 Share Posted September 3, 2022 On your Amp Out question, go to Global Settings. You can set the AMP OUT source to work the same as Main Out. Quote Link to comment Share on other sites More sharing options...
