3.01 no more option to disable Volume knob for Out to Amp
shemeshg
Hi
System setting has no more the option of Volume Knob – control only USB. (like in 2.X)
This is a problem assuming you’d like the output level goes from your ¼ Out to the amplifier depend only on what is set on your preset and not also the Volume Knob.
"The volume knob never controlled the USB output" - exactly
But in previous release you could
- connect Guitar to Helix,
- Helix to Amplifier
=> turning volume knob even to zero, and the level goes to the amplifier would be the same as set on the Preset...
Now, 3.x accidentally turning volume knob down and you will not hear the guitar or change your tone.
on 2.X you could set if you want Volume knob to control your Output Jack or just your headphones and USB.
No such option now....
The large volume knob never controlled the USB output.
The update does mess with your global settings, though. Based on your other thread, I’d recommend you’d do a factory reset (hold FS7 and FS8 while powering up), and then do a Restore from Backup.
Just reset global settings and -
In global settings "Ins/Outs" I have only one page with the options
Guitar in pad: off
1/4 outputs: instrument
XLR outputs: Mic
Send/Return 1: instrument
Send/Return 2: instrument
USB Destination: Multi
No option for setting the Volume Knob..
Am I looking in the wrong location?
Guitar in pad: off
XLR outputs: Mic
Hit the Page > button. There’s a bunch more settings under Ins/Outs.
Guitar in pad: off
XLR outputs: Mic
Btw, this applies to global settings and even things like amp and effect blocks. If the bar towards the bottom of the screen is only lit partially that means there are more parameters you can page over to.
