Helix LT: two different amp blocks two different imported ir blocks !
Guido_59
I would create a preset with two different amp block with two different ir blocks imported. The two amp blocks should be Small tweed and baseman for example , and it impulses imported for Red Wirez.
I have tried to do using 1024 ir I creat a parallel chain with a second amp block but I cannot choose a second different it block. I can use the same ir.
Is there a way to do what I want?
Excuse me for my language
Bye
Edited by Guido_59
Hello guys. Problem solved.
Cause mistake I have loaded impulse at. 96khz from Red Wirez, so DSP  conversion capability to 48khz was probably too low. So I have loaded an original 48khz impulse as 1024 and by this way I was able to load 2 impulse at 2048 or 4 at 1024.
Thanks all of you.
