DT 25 Newbie Qustions
ToneRanger57
Hi all I have a DT 25 Head with a DT25 112 1x12 Guitar Speaker Cabinet. Is there any advantage to having another cabinet , would it do anything for my overall tone. I also have a Pod HD 500x which is connected by a Monoprice 6 Meter (20ft) 3-pin DMX Lighting & AES/EBU Cable via the L6 Link is this cable giving me full compatibility between the DT25 and the pod thanks in advance.
This is the cable spec:
This cable is designed for accurate transmission of digital audio and DMX lighting control data. It features a twisted pair of 22AWG conductors wrapped in a double layer shielding composed of copper braid and aluminum foil. The two shield layers combine to provide 100% shield coverage for the conductors.
The input end of the cable is terminated in a 3-pin male XLR connector, while the output end terminates in 3-pin female XLR connector. The cable has a nominal impedance of 110-120 ohms.
I'm not sure on what adding another cabinet will do, others might be better suited to answer that one. As for the L6 link cable you have would work fine as DMX is a digital signal and this is what the L6 link uses, and the specs are correct with impedance of 110-120 ohms. A typical microphone cable would have a impedance of 45 ohms and should only be use in a pinch and a shorter cable the better.
Jd
