doomtoof Posted January 11, 2021 Share Posted January 11, 2021 I'm having the hardest time figuring out how to change the sample rate of the HX Stomp from 48khz to 44.1, and I've tried everything! I can't change it within protools, or creating a new session, I can't change it in system preferences. I just want to be able to use it in 44.1 protools sessions. It's becoming so frustrating! Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 11, 2021 Share Posted January 11, 2021 13 hours ago, doomtoof said: how to change the sample rate of the HX Stomp from 48khz to 44.1 Install the Helix Driver, v.1.0.9, or if you're on El Capitan or earlier v 1.0.7. The Stomp is class compliant, i.e. it is usable without a driver, but only @ 48kHz. Quote Link to comment Share on other sites More sharing options...
zolko60 Posted January 11, 2021 Share Posted January 11, 2021 Albeit be aware that the both methods have their pros and cons. Quote Link to comment Share on other sites More sharing options...
doomtoof Posted January 24, 2021 Author Share Posted January 24, 2021 Okay so I installed the driver but i am still not allowed to change the sample rate inside of pro tools or in the sound menu. Here's some screenshots of the stuff im encountering Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 24, 2021 Share Posted January 24, 2021 7 hours ago, doomtoof said: Here's some screenshots of the stuff im encountering Then the driver is possibly not installed properly yet? Here's what it looks like on El Capitan: Quote Link to comment Share on other sites More sharing options...
doomtoof Posted January 24, 2021 Author Share Posted January 24, 2021 I am on big sur if that matters. Quote Link to comment Share on other sites More sharing options...
doomtoof Posted January 24, 2021 Author Share Posted January 24, 2021 I went through the whole installation process including the restart. I wonder if I should downgrade to El Capitan or something? Quote Link to comment Share on other sites More sharing options...
lou-kash Posted January 25, 2021 Share Posted January 25, 2021 15 hours ago, doomtoof said: I am on big sur if that matters. Um… yes: Quote MacOS 11 Compatibility with Line 6 Software × By Line6Tony 09/11/2020 Apple® released their new operating system, macOS® 11 Big Sur, today. Currently, Line 6 software products are not compatible with macOS 11 Big Sur. We recommend that you wait until Line 6 software product compatibility with macOS 11 is announced before updating to the new operating system. Compatibility is currently being tested and will be ensured in upcoming software updates. To prevent macOS from automatically updating, uncheck the “Install macOS updates” option in System Preferences > Software Update > Advanced. Please watch this space for more information regarding support for macOS 11. The Line 6 Support Team That's what you'll see if you click on the "MacOS 11 Compatibility with Line 6 Software" box at the top of every forum page. It's there for a reason. 15 hours ago, doomtoof said: I wonder if I should downgrade to El Capitan or something? Definitely do not use Bug Sur for "mission critical" tasks roughly until at least the upcoming WWDC later this year. Provided your ProTools is fully compatible with Catalina, you should be good to go with Line 6 on Catalina as well. 1 Quote Link to comment Share on other sites More sharing options...
pablocubico Posted Monday at 03:49 AM Share Posted Monday at 03:49 AM In case anyone finds this useful: I'm in Catalina and can confirm you change the Sample Rate. At first nothing happened, I downloaded the appropiate driver (1.1.0), then I restarted, gave Line 6 some system Services permissions, then restarted again. No Sample Rate dropdown yet. But as I did all of these restarts, I never turned off the HX Stomp unit. Only after turning it down and on again it picked up the right driver. Quote Link to comment Share on other sites More sharing options...
