Cee_Doublebass Posted January 15, 2021 Share Posted January 15, 2021 Hello there, i have problems with the communication between the HX Edit and the HX Stomp. The Stomp just doesn't do what the Edit wants... Some presets seem to be not working since the 3.0 Update. If Iwans to export them to my favorite I get a message -8606 - Unexpected or bad data type in preset. If want to get to these presets by double-clicking in the Edit it changes in the Stomp but not in the window of the edit. Presets are somehow not saved though I am sure I did. I tried to build up presets new, but that appears to become complicated, because I just don't get to that preset. If I switch there from the previous preset, the display in edit just stays in the previous, though in the HX Stomp it changes to the next one. Can someone help? Cheers CW Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 15, 2021 Share Posted January 15, 2021 Did you download and install HX Edit 3.0? Quote Link to comment Share on other sites More sharing options...
Cee_Doublebass Posted January 15, 2021 Author Share Posted January 15, 2021 Yes Quote Link to comment Share on other sites More sharing options...
datacommando Posted January 15, 2021 Share Posted January 15, 2021 1 hour ago, Cee_Doublebass said: Some presets seem to be not working since the 3.0 Update. When the update of the firmware to version 3.01 finished did your HX Stomp go through the “Rebuilding Presets” routine and reset itself? If not have you tried performing one of the Hardware reset options yourself? Also try restoring your presets from the backup file which you made before the firmware update. Here ya go! HX Stomp Button Combination Description All 3 Footswitches Clears all presets/IRs FS1+2 Resets presets and IRs FS 2+3 Factory restore (globals, presets, IRs Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
