Need Help connecting to Computer
coolguy26507
23 hours ago, coolguy26507 said:
I was using that. Is it a specific cable? I was using a cable that could fit
It's a standard USB equipment cable, square end on the pedal side, standard USB on the other end.  Should have come with the pedal, if you bought it new. A CAT5 cable connects the pedal to the amp.   Don't connect the FBV MkII to the computer with a CAT5 cable.
Ok. So just an Rj45 to USB adapter to my pc and it should work?
No no no!  There are 2 jacks on the FBV Mk11 pedal - one is the RJ45 (Cat5) for connecting the pedal to the amp.  The other is a USB (square type) for connection to a computer.  If you connect the RJ45 to your computer you could fry the pedal.
Alright got it. Thanks
  • 7 months later...
  • 2 years later...
Spider IV 15 doesn't work with the editing software which is why I bought the Spider Classic 15 which was advertised as working with the editing software but now tech support is telling me that it does not. You have to have a 75 and up to work with the editing software.
