Bass IR’s for Pod Go
Kingdondo
The grgr.de IRs seem pretty cool, they even have some IRs with built-in reverbs, so I`m not sure how they compare to the L6PGO spring reverb for instance, but could be useful if the sound of the IR works out for you and you are running low on PGO resources or just want an additional block! (Using IR as reverb = saves 1 block!)
[edit: although...  It might just be the reverb without an amp, so might not really be useful with Go with typical usage...]
