Tap Tempo Reverb Pre Delay
jaxonhargrove
Hello!
Does anyone know if it is possible to assign the tap tempo switch to control the pre-delay on any of the reverb blocks in HX Effects? I have an EHX Cathedral that does this and it has become one of my go to delay/reverb sounds. I'm wondering if this is possible within HX. I thought about creating a custom block that includes both a reverb and a single repeat delay set to full wet before the verb, but i'd love to find a cleaner way to do it. Anybody have any thoughts?
  • 2 months later...
So far the only way I’ve found is to pull a delay down to path b, set it to a single  repeat, 1/4 or 1/8th note and 100% wet. Then put a reverb on 100% wet behind it and use the “level” control on the reverb to mix it back into path a. It works, but it takes some time to setup and isn’t very intuitive.
