Michi21995 Posted February 24, 2021 Share Posted February 24, 2021 Hi guys ! I have a question because I got really confused how Send and Return blocks work on HX Stomp. I use my HX Stomp instead of a pedalboard and I really like it. Im just curious if one other thing is possible. I want to send signal from my AMP Effects LOOP into the HX Stomp, then run the signal thorugh an IR block and then send it to the PA. So I want to do this : Guitar -> HX Stomp ( used as a pedalboard ) -> My amp input and at the same time My amp effects loop -> HX Stomp ( used for IR ) -> PA Is that possible ? If so - How can I achive this ? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 24, 2021 Share Posted February 24, 2021 Yes, there are multiple ways: Solution 1 Put a fx return block 100% mix in parallel (signal line B) near the end and a cab block behind that. Then the mixer after that with signal A pan 100% left and signal B 100% right. A) O--- FX blocks------------------------------o-----O B) \_Return L --- IR--/ Putting the loop send of the amp in the return of the HX Stomp. Now Out L contains the signal for the amp and Our R contains the IR signal for PA. Solution 2 A) O--- FX blocks----------FX LOOP ------------ IR-------O Put the send signal from the Stomp into the amp input and the amp send signal into the Stomp return. The outs now contain the PA signal. Solution 3 A) O------- FX blocks----o-----O B) \--- ---- IR------------/ Put the loop send of the amp in the right input of the HX Stomp and guitar in the left input. Use a Split Y with BalanceA L100 and BalanceB R100 in the beginning. At the end a mixer with signal A pan 100% left and signal B 100% right. Now Out L contains the signal for the amp and Our R contains the IR signal for PA. Quote Link to comment Share on other sites More sharing options...
