Michi21995
Can HX Stomp do that ??
Hi guys !
I have a question because I got really confused how Send and Return blocks work on HX Stomp.
I use my HX Stomp instead of a pedalboard and I really like it.
Im just curious if one other thing is possible.
I want to send signal from my AMP Effects LOOP into the HX Stomp, then run the signal thorugh an IR block and then send it to the PA.
So I want to do this :
Guitar -> HX Stomp ( used as a pedalboard ) -> My amp input
and at the same time
My amp effects loop -> HX Stomp ( used for IR ) -> PA
Is that possible ? If so - How can I achive this ?
Yes, there are multiple ways:
Solution 1
Put a fx return block 100% mix in parallel (signal line B) near the end and a cab block behind that. Then the mixer after that with signal A pan 100% left and signal B 100% right.
A)  O--- FX blocks------------------------------o-----O
B)                                  \_Return L --- IR--/
Putting the loop send of the amp in the return of the HX Stomp. Now Out L contains the signal for the amp and Our R contains the IR signal for PA.
Solution 2
A)  O--- FX blocks----------FX LOOP ------------ IR-------O
Put the send signal from the Stomp into the amp input and the amp send signal into the Stomp return. The outs now contain the PA signal.
Solution 3
A)  O------- FX blocks----o-----O
B)      \--- ---- IR------------/
Put the loop send of the amp in the right input of the HX Stomp and guitar in the left input. Use a Split Y with BalanceA L100 and BalanceB R100 in the beginning. At the end a mixer with signal A pan 100% left and signal B 100% right. Now Out L contains the signal for the amp and Our R contains the IR signal for PA.
