palladinojt
FEATURE REQUEST - VU meter enhancement
I would very much like to see the VU meter functionality expanded in a few ways:
(1) I would like the meters to be visible at all times (at least in HX Edit if not on the device itself), not just when the Output Block is selected.  If I am running a dual signal path with each path panned L and R, and I want to make sure they are properly level balanced, I can't see the levels for both of them at the same time, because I can only select one Output Block at a time.
(2) Ideally the meters would be graduated.
  • Thanks 1
Feature requests need to go in Ideascale... nobody in a position to do anything about it will see it in here.
Thank you.  This was my first feature request; wasn't sure where to go.
Ping here with the ideascale link when it's done. I'm gonna vote it for sure. o/
