Louder Right channel
themetallikid
So Im sending stereo L/R outs from Helix into two separate channels on my mixer.  I'm noticing in the metering and channel lights that the Right channel is about 3db louder on the input trim meters.
In my headphones it doesnt sound that way, and gauging from the 3.0db boosts I use on some lead presets Id think I'd hear that.
I've checked my path 2A>2B split and there is nothing here that indicates why.  I have the 2A and 2B outputs hard L/R 100%  the last block(s) after my stereo split of the path are just IR blocks.  One is set to more of a 57 biting type sound and the other is more of a 121/160 type mic.
Am I safe to assume its a bit of the Fletcher effect being the bassier is the 'right' channel that the input is more sensitive to lower frequencies then?
Did you troubleshoot in a DAW with the helix as soundcard recording input 1/2 and watching the meters there? That would effectively bypass all analog stages except input. If the L/R levels are matched there but not when going to your analog mixer something in the analog domain might be pthe problem
