NOAMTAYAR
Hx stomo to fx reurn of an amp
Hello to all,
I'm running my stomp into my SS amp's return mono ( it's a 2X12 8240 stereo Marshall).
the problem is that only one speaker works. The patch is one mono amp ( no cab).
so I tried to go in the FX  stereo (LEFT AND RIGHT) return of the amp. still, only one speaker works.
The patch I'm using is mono.
If I go with the guitar to amp's input, both speakers work
what am I doing wrong?
Is the problem coming from the stomp or patch? or is it because of my SS amp?
TNX
Not describing the type of cables you're using, from which HXS Outputs to which VS inputs.
Your amp's return path probably is faulty. Connect a cable from amp's send to return left/mono directly to confirm that.
problem solved!
the last block of the chain needs to be in stereo.
that's it.
tnx to all
