Delay Issue
Hatman777
Hello All i was wondering what setting needs to be changed when In example my delay settings (time) are different from one patch to the other, when i switch patch i get this weird  delay artifact noise for lack of a better word,  i tried both global settings in tap from authentic to  transparent  but the weird  time switch artifact is still present on either or
any other parameter i can look at ?
Thank you all for your valued input
When you are in Global Settings, set the TAP to transparent, but also ensure that the TAP TEMPO is set to Global.
See if that helps.
  • Thanks 1
Hello Data Commando,  So i tried what you  suggested yet its still present  Here are the 2 Different delay settings  im using for the 2 Different patches
Maybe its in the Delay Note sync settings  ?
Again thank you for your valuable help  much appreciated
Or maybe, as I can see from you screen shots, something else is involved in this equation?
Those [white brackets] around the Sync, Feedback etc., would indicate that those numbers are variable and controlled by something else - Snapshots for example?
This could be where the issue is arising.
Have you tried to tie the tempo to the snapshots?
