Ubdate problems Helix LT
Pauloclass1967
4 hours ago, Pauloclass1967 said:
Can anyone help me?
Someone possible could help you, but you really need to supply as much relevant information as you can. Simply saying that the update process failed is not enough. Luckily the “Boot Failure, Entered Update Mode” message is quite common and if you search the forum there are many posts with suggested solutions that may fix this quickly.
If you cannot find the solution on here, then you really must supply the required details for someone to assist you. You know the sort of thing - what firmware were you updating from and to, what computer platform and OS you are using and exactly how you were performing the update and did your computer enter sleep mode during the procedure?
Help us to help you.
