buford Posted March 11, 2021 Share Posted March 11, 2021 Greetings fellow musicians: I found some cool tones online that are from an HD stomp box. Am I able to down load to the PodGo? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 11, 2021 Share Posted March 11, 2021 No. You mention an HD Stomp. I’m not sure whether you’re talking about a POD HD device or an HX Stomp.But the answer is the same in either case. Quote Link to comment Share on other sites More sharing options...
buford Posted March 11, 2021 Author Share Posted March 11, 2021 Hello Silverhead. I have the new Pod Go. I found the tones from Rick Beato and he advertises they were made on a Line6 HX Stomp. It sounds like the answer is no. Thank you for the quick follow up. Quote Link to comment Share on other sites More sharing options...
OmegaSlayer Posted March 13, 2021 Share Posted March 13, 2021 Though, a conversion program should be needed, as 95% things without split signal would work Quote Link to comment Share on other sites More sharing options...
voxman55 Posted March 13, 2021 Share Posted March 13, 2021 1 hour ago, OmegaSlayer said: Though, a conversion program should be needed, as 95% things without split signal would work The DSP processing difference is the problem and there are some key differences in functionality too. Quote Link to comment Share on other sites More sharing options...
OmegaSlayer Posted March 19, 2021 Share Posted March 19, 2021 On 3/13/2021 at 12:38 PM, voxman55 said: The DSP processing difference is the problem and there are some key differences in functionality too. Indeed, but I think the engineer can find some workaround The point is only a matter of time/profit Quote Link to comment Share on other sites More sharing options...
voxman55 Posted March 19, 2021 Share Posted March 19, 2021 38 minutes ago, OmegaSlayer said: Indeed, but I think the engineer can find some workaround The point is only a matter of time/profit No it's absolutely not. Pod Go and HX Stomp are fundamentally very different units and the architecture and DSP processing are both quite different. You can't put 4 pints of milk into a 1 pint bottle or a square peg into a round hole. That's exactly why Line 6 has quite correctly positioned Pod Go as 'Pod' family and not part of the Helix family - it has Helix modelling, but it is NOT a Helix. 1 Quote Link to comment Share on other sites More sharing options...
