ddufour
No Sound When Turned On
I only have it plugged into a powered speaker. Sometimes when I turn the unit on, there is no sound.
Turning dials or changing patches doesn't help. I actually have to shut it off and turn it back on and then I have sound.
It's been doing this for many months and never really got concerned about it until this past weekend. It took 3 shut offs
and start ups to get sound. Now I'm concerned whatever is going on may get worse and eventually not have any sound.
Anyone else have this issue?
Dan
are you using the latest firmware?  There was no sound issues that were fixed, so if not up to date, update!
I hate to be that guy but have you switched out the cables you are using.
I have done 1 update since I purchased it. Don't know if it is the latest. At work right now.
I get the point about cables and I can certainly try switching some the next time but I
do know none of the cables move between turning the unit on or off so there should not
be any shorts. I am using a power strip with an on and off button to turn on the pod and speakers
at the same time.
You're in luck!  New update just released, install and check if it fixes your issue!
