Samdbl Posted March 31, 2021 Share Posted March 31, 2021 So, if I turn off the cab and preamp blocks of the pod go, then I go from the amp out into the front of an amp, I am simply running a pedal chain into an amp, correct? I’m not doubling up on preamps as the preamp and cab blocks are turned off, correct? Or is there still a preamp of some sort present in the chain? Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 31, 2021 Share Posted March 31, 2021 As long as you have the input pad off, that should give you unity gain (assuming you have all other blocks bypassed). Quote Link to comment Share on other sites More sharing options...
Samdbl Posted March 31, 2021 Author Share Posted March 31, 2021 35 minutes ago, phil_m said: As long as you have the input pad off, that should give you unity gain (assuming you have all other blocks bypassed). right. But I don’t want the eq of a preamp/cab sim to interfere with the chain, either. Like, I’d like to use it as I would use my hx effects on occasion. So off is off, correct? I’m trying to evaluate this thing before the return date is up. It’s kind of looking like, unlike any of the other units, this unit is *only* for being used as an amp sim with an amp out only as an afterthought for monitoring or effects loop (which none of my vintage amps have). Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 31, 2021 Share Posted March 31, 2021 2 minutes ago, Samdbl said: right. But I don’t want the eq of a preamp/cab sim to interfere with the chain, either. Like, I’d like to use it as I would use my hx effects on occasion. So off is off, correct? I’m trying to evaluate this thing before the return date is up. It’s kind of looking like, unlike any of the other units, this unit is *only* for being used as an amp sim with an amp out only as an afterthought for monitoring or effects loop (which none of my vintage amps have). Yes, if you bypass the block, it jut passes the signal through it, unaffected. Quote Link to comment Share on other sites More sharing options...
poodad Posted March 31, 2021 Share Posted March 31, 2021 Another way to do this is to put the send/return block in front of the amp and turn the effects send on. Connect the effects send jack to your amp. This comes in handy if you want to use a real amp AND a PA (or other full range system). Use a 1/4" stereo Y cable (male, female, male) to jump effects out to effects in, and tap off to the guitar amp. This way you send your post effects signal to you amp and also into the amp/speaker simulators to go to the PA. Quote Link to comment Share on other sites More sharing options...
