Poly Sustain drops out on Snapshot change
rappel353
Yes, that can be normal. One of the most common uses of snapshots is to toggle FX blocks on/off as you switch snapshots. This is independent of any parameter changes being assigned to the Snapshot controller. If you want the block to be ON in all snapshots, one way to do it is to visit each snapshot individually, turn the block on manually, and Save the preset before visiting the next snapshot.
Thank you all for your informative replies.
PierM, Thank YOU for making me aware of that function. I had never seen it before and probably would not have understood what it did even if I had.
I set Snapshot Bypass to Off for the Poly Sustain block and now it works the way I had hoped.
Again, thanks to all who responded so quickly.
Bob
