5mafre5br Posted April 4, 2021 Share Posted April 4, 2021 1) HX Edit, I want my wah pedal to be initially on, so I dont have to press the pedal toe to turn it on. How do I do that? 2) How can I set the level to be louder at the lower frequencies (heel down)? I dont know how to do controller assign, so detailed instructions would be helpful. thanks Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 5, 2021 Share Posted April 5, 2021 18 hours ago, 5mafre5br said: 1) HX Edit, I want my wah pedal to be initially on, so I dont have to press the pedal toe to turn it on. How do I do that? Just save preset/snapshot with the wah block active. 18 hours ago, 5mafre5br said: 2) How can I set the level to be louder at the lower frequencies (heel down)? I dont know how to do controller assign, so detailed instructions would be helpful. You didn't say which HX device you have. On the Helix do the following: Create wah and volume blocks and make sure both are active(lit) then highlight/select the Volume block Press the "≡" button (Note: Make sure your Volume block is selected first per step #1) Press Controller Assign Set the parameter 'Controller' = "EXP Pedal 1" (if your wah block is assigned to "EXP Pedal 1") Set 'Min Value' = 100%, Set 'Max Value' = 0% (notice you are reversing the default values, also, if you don't want the volume to go all the way to zero in the toe-up position or to max out at the toe-down position then adjust the Min/Max Value settings accordingly) Save your preset Note: You can edit the assignments further in HX Edit or on the device as needed if you decide to get the toe switch involved. 1 Quote Link to comment Share on other sites More sharing options...
