Gkf9 Posted April 10, 2021 Share Posted April 10, 2021 Can anyone explain to me how the lighting bolts work in the command centre, I'm after setting up amp changing per snapshot, do the bolts represent the 6 switches on the Helix effects? Do I have to select one per snapshot? I'm using the TRS cable method. I have read the manual, but it doesn't explain much. TIA Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 10, 2021 Share Posted April 10, 2021 All six commands are sent out when you load a preset and/or load a snapshot. Commands are only sent out per snapshot if the snapshot you're going to has a different value for a command than the one you're coming from (MIDI PCs would be the exception to this if you have the Duplicate PC Send setting to On in the Global Settings menu). 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 10, 2021 Share Posted April 10, 2021 When you load a preset or a snapshot, the commands assigned to the "lightning bolts", properly called "Instant Commands" (IC) are executed in order. They are not directly related to the footswitches. Each snapshot can have different commands assigned to the ICs. If SS1 executes command X on IC1, subsequent snapshots will not execute command X until a snapshot executes command Y. Example - IC1 in SS1 and SS2 both send a TIP message. IC1 in SS3 sends a RING message. SS1 is the default (the SS saved with the preset). When you load the preset, the TIP message is sent. If you switch to SS2, it is not sent again. If you switch to SS3 the RING message is sent. If you then switch to SS1 or SS2, the TIP message is sent again. I'm not at home with my HX Floor, I'm on the road with my HX Stomp, which does not have the switching feature. While the above rule applies to MIDI commands, I'm not 100% positive that it applies to the switching commands. You can test this with a TRS cable and a multimeter. If you use Toggling CCs on the footswitches (you can't use them on ICs), each time the preset or a snapshot loads, it will send the Toggling CCs (true also for NOTES, I believe). Regular (non-toggling) CCs are not sent when the preset/snapshot loads (unless assigned to ICs). There's probably more, but that's the important stuff, and my breakfast is ready! :-) EDIT: Plus what phil_m said. 2 Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted April 10, 2021 Author Share Posted April 10, 2021 Thank you very much guys for the explanations, I think I understand now a little more, I'll have another mess later and use this information. Thanks again. Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted April 15, 2021 Author Share Posted April 15, 2021 I've manged to set 4 snapshots up with IC, Clean channel and dirty channel. But when I go into Stomp mode, the IC I set up to toggle the amp clean and dirt up on a switch doesn't seem to work right. Is this my amp, or can I not do both snapshot and stomp to.change channel with ICs? Again sorry if this as been answered above, but it's a little confusing for my small brain. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 15, 2021 Share Posted April 15, 2021 11 minutes ago, Gkf9 said: I've manged to set 4 snapshots up with IC, Clean channel and dirty channel. But when I go into Stomp mode, the IC I set up to toggle the amp clean and dirt up on a switch doesn't seem to work right. Is this my amp, or can I not do both snapshot and stomp to.change channel with ICs? Again sorry if this as been answered above, but it's a little confusing for my small brain. "It doesn't work right" doesn't mean anything to anybody but you. What is it SUPPOSED to do? What EXACTLY, does it do? What is your hardware configuration? Amp, etc.? For BEST results, attach the preset to your reply to the above questions so we can see what's happening in your configuration. 1 Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted April 15, 2021 Author Share Posted April 15, 2021 (edited) 7 hours ago, bobcoss said: Sorry if I've misled you. I've always been able to update my HXE and Helix Floor with Line 6 Updater under windows. Don't know if Mac or older versions of the operating systems have anything to do with it. 1 hour ago, rd2rk said: "It doesn't work right" doesn't mean anything to anybody but you. What is it SUPPOSED to do? What EXACTLY, does it do? What is your hardware configuration? Amp, etc.? Edited April 15, 2021 by Gkf9 mistake Quote Link to comment Share on other sites More sharing options...
Gkf9 Posted April 15, 2021 Author Share Posted April 15, 2021 I am using a Blackstar HT20 MK II It has 2 channels, clean and Overdrive and then 2 different voicings on each channel. I just really want 2 channels clean and dirty without the other voicings. I have set 3 snapshots up, first 2 are clean and the 3rd switching my amp to the dirty channel. IC 1 Snaphot one set to none, this is the clean channel IC 1 Snapshot two set to none, clean again. IC 1 Snapshot three set to Tip+Ring this changes the amp to dirt. Now when I go into stomp mode, I wanted FS6 to be my dirt channel, I could toggle on/off I have assigned an IC to Fs6, Tip+ring ( same as IC1 Snapshot three, thinking this would be the dirt channel ) but it turns one of the other amp voicing on. and then sends my previous settings I did for the snapshots earlier, out again, IE the different voicing start coming on and off. If I clear the foot switch command it starts to behave again. Hope this makes sense? I am really enjoying the unit so far, just this small niggle letting me down, no doubt It is user fault or my amp? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 15, 2021 Share Posted April 15, 2021 PLEASE attach the preset. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 15, 2021 Share Posted April 15, 2021 44 minutes ago, rd2rk said: PLEASE attach the preset. “Sigh” Quote Link to comment Share on other sites More sharing options...
