racerx632 Posted April 14, 2021 Share Posted April 14, 2021 New Issue. The pd go will just randomly reboot. Newest divers and software installed. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted April 14, 2021 Share Posted April 14, 2021 Not heard this before. Suggest that the first thing to do is create a full back up, then reset your Pod Go back to factory by switching off, and then restarting whilst holding down buttons C & D. then reimport your saved patches. Most often these things are a minor software-filepath corruption, which the reset will fix 95% of the time. If you still have problems after doing this, I recommend you raise a ticket with Line 6 support and attach a copy backup for them to look at. But I'm reasonably confident the reset will fix it. Quote Link to comment Share on other sites More sharing options...
racerx632 Posted April 14, 2021 Author Share Posted April 14, 2021 i'll give that a go. Thanks. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted April 15, 2021 Share Posted April 15, 2021 I have not seen a single spontaneous reset on the GO...You can try reflashing, but that is doubtful IMO. That sounds a more like a power supply problem IMO. you could have janky PSU or maybe it just wan't fully plugged in...might be worth giving the wire a jiggle to see if it's a contact issue...The PSU for my HD Desktop failed in a similar way when it was nearly exactly 10 years old. I replaced the PSU and works like it always did. Those have a little green LED on the PSU, so it was pretty clear that it was going bad and it was pretty old. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted April 16, 2021 Share Posted April 16, 2021 16 hours ago, spaceatl said: I have not seen a single spontaneous reset on the GO...You can try reflashing, but that is doubtful IMO. That sounds a more like a power supply problem IMO. you could have janky PSU or maybe it just wan't fully plugged in...might be worth giving the wire a jiggle to see if it's a contact issue...The PSU for my HD Desktop failed in a similar way when it was nearly exactly 10 years old. I replaced the PSU and works like it always did. Those have a little green LED on the PSU, so it was pretty clear that it was going bad and it was pretty old. That thought had occurred to me too. It's possible, but if there was a loose connection I'd have expected all power to go and the screen to go blank, rather than reboot. I still think it could be a possible software glitch but I agree it's certainly worth checking the PSU for a loose connection. Quote Link to comment Share on other sites More sharing options...
racerx632 Posted April 16, 2021 Author Share Posted April 16, 2021 reset didn't work. I'll hit up support. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted April 16, 2021 Share Posted April 16, 2021 2 hours ago, racerx632 said: reset didn't work. I'll hit up support. Thats annoying. Did you check the PSU for a loose connection? Quote Link to comment Share on other sites More sharing options...
racerx632 Posted April 16, 2021 Author Share Posted April 16, 2021 yea it doesn't have any obvious issues Quote Link to comment Share on other sites More sharing options...
voxman55 Posted April 16, 2021 Share Posted April 16, 2021 How frequently is your Pod Go Rebooting? What firmware version are you on and which version of Pod Go Edit do you have installed on your computer? Quote Link to comment Share on other sites More sharing options...
racerx632 Posted April 16, 2021 Author Share Posted April 16, 2021 1.21 firmware. 1.21 pod go edit. It will do it every time i use it. will reboot and typically reboot again a couple times after. I'll end up powering it off and on again hoping that helps and typically it will be ok until the next time i use it. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted April 16, 2021 Share Posted April 16, 2021 6 hours ago, racerx632 said: 1.21 firmware. 1.21 pod go edit. It will do it every time i use it. will reboot and typically reboot again a couple times after. I'll end up powering it off and on again hoping that helps and typically it will be ok until the next time i use it. Definitely one for Line 6 Support to sort out for you. When you raise a ticket, send them a copy of your back up to see if they can reproduce the issue (in case it's a software glitch that they might be able to resolve) - if not, it's more likely then the Pod Go unit itself - & if so they will arrange for a replacement for you. 1 Quote Link to comment Share on other sites More sharing options...
