Sykul03 Posted April 20, 2021 Share Posted April 20, 2021 I need help - I have a great snapshot of a clean tone in one preset, and several crunch tones in another preset. I need those snapshots in the same preset. I don't know how to do all that :) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 21, 2021 Share Posted April 21, 2021 Assuming that both presets use the same blocks, you can copy down the settings from the snapshots of each block of one preset and apply them manually to the blocks/snapshots in the other preset. Yes, a tedious PITA, but that's your only option. There's no way to merge presets, or copy a block with all of it's various snapshot settings. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 21, 2021 Share Posted April 21, 2021 12 hours ago, Sykul03 said: I need help - I have a great snapshot of a clean tone in one preset, and several crunch tones in another preset. I need those snapshots in the same preset. I don't know how to do all that :) As noted by “rd2rk” in the post above, you can’t simply copy and paste snapshots from a location in one preset, to another in a different preset. Your best option is to duplicate the preset with the “several crunch tones”. Then write down all the snapshot settings you have in the “clean tone” and add those settings into the crunch patch. Possibly less things to recreate this way round. There is no shortcut for this, but it works. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted April 21, 2021 Share Posted April 21, 2021 I personally copy each effect from one patch and put it in the other one at a time. It will maintain that blocks settins. Then do it again for each block. A pain but it's the only way now. Don't forget to save your patch after everytime you paste. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted April 22, 2021 Share Posted April 22, 2021 I would save everything in your clean patch as a favorite, then add those blocks where necessary into your crunch patch. I have done this when creating song specific presets. Unless I'm missing something in your request. If you have duplicate blocks, say an EQ in both presets, I will usually insert both favorites, and then add the changes between them to one of the blocks via snapshot changes, then delete the duplicate not needed block. Quote Link to comment Share on other sites More sharing options...
AgFx Posted May 6, 2021 Share Posted May 6, 2021 Wouldn't the favorites feature be a help here? Make all the crunch tone blocks favorites, then add those favorites to the clean tone preset, and finally so some footswitch/snapshot magic to switch blocks on and off as needed...? Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 6, 2021 Share Posted May 6, 2021 2 hours ago, AgFx said: Wouldn't the favorites feature be a help here? Make all the crunch tone blocks favorites, then add those favorites to the clean tone preset, and finally so some footswitch/snapshot magic to switch blocks on and off as needed...? That is not a bad idea at all. I still wish I could copy a whole path and paste it in another patch. Quote Link to comment Share on other sites More sharing options...
