teddybut Posted April 25, 2021 Share Posted April 25, 2021 (edited) Hi Everyone, Enjoying the 3.10 update very much. I have a weird problem with HX Effects. In a preset, I assign buttons to snapshots with Command Center. No efx have buttons assigned. 3 of the buttons behave as desired. You click on the button and the snapshot comes to life. One of the buttons, #3 in this case, requires 2 presses to activate the snapshot... the weird part is: after I select the preset it works fine the first time. Every subsequent time after that requires 2 presses to activate the snapshot. Very strange behavior. I don't know if it's a new problem because I never used snapshots before 3.10. I know I could use snapshot mode and not even use command center to do this, but I have a couple of momentary efx I want to turn on and off for this patch. here's a video of it. https://www.dropbox.com/s/3d4v93o3gra2qni/HX command center bug sm.mov?dl=0 Edited April 25, 2021 by teddybut didn't state what box I was using Quote Link to comment Share on other sites More sharing options...
teddybut Posted May 3, 2021 Author Share Posted May 3, 2021 I swapped the snapshot to button 1 instead of 3 and now it works perfectly. Does that mean my 4th button is messed up or can anyone else duplicate this behavior? Quote Link to comment Share on other sites More sharing options...
