Hepnotic Posted April 27, 2021 Share Posted April 27, 2021 I'm using a Marshall CODE 25, and a Roland Micro Cube. I love how great the modulation effects are in stereo, and I just like the sound of guitar that way. I have both connected from their AUX input jacks, into each of the MAINS output jacks. Similar to having it setup to studio monitors I suppose. I figured out how to disable all cabs globally, but it only applies to the GUITAR IN jack. I can't make it apply to the MAINS outputs. I know I can disable the cabinets manually on each preset, but i'll need to use them when using headphones or recording. I tried using a Y splitter to connect both amps to the guitar jack, but then I lose the stereo effect. I know you can assign one of the footswitches to toggle the cabinet on/off. If that can be done globally for all the presets, perhaps thats the best workaround? Also, my main out setting is on level. Would I be better off setting it to instrument, and connecting the pod to the guitar input jacks on my amps instead of the aux inputs? Thank you for the help! Quote Link to comment Share on other sites More sharing options...
poodad Posted April 29, 2021 Share Posted April 29, 2021 Use a stereo Y cable (male/male/female) to connect the pod go's effects out to effects in. In your signal chains, put the effect send/receive before the speaker sim. Or even before the amp sim if you want. On the female of that Y cable, plug another Y cable in that splits the stereo into two mono signals. Connect each of those to each amp. By moving the effects send/receive in the chain, you can tap off stereo signal at any point you like. 1 Quote Link to comment Share on other sites More sharing options...
scotterp Posted April 29, 2021 Share Posted April 29, 2021 ^^^^^ I never even thought of doing something like this. Not that I need it at this point but now I might try to find a reason to! Quote Link to comment Share on other sites More sharing options...
Hepnotic Posted May 4, 2021 Author Share Posted May 4, 2021 On 4/29/2021 at 10:05 AM, poodad said: Use a stereo Y cable (male/male/female) to connect the pod go's effects out to effects in. In your signal chains, put the effect send/receive before the speaker sim. Or even before the amp sim if you want. On the female of that Y cable, plug another Y cable in that splits the stereo into two mono signals. Connect each of those to each amp. By moving the effects send/receive in the chain, you can tap off stereo signal at any point you like. Thank you! I’ll try doing this. Quote Link to comment Share on other sites More sharing options...
