paul6492
Podgo clipping
Hey there anyone having clipping problems,  I thought it was my daw but bypassed podgo and there's no clipping,  just started out of the blue
Going to need some more details here... Where are you hearing or seeing clipping and how do you have things connected?
Maybe you had the PAD turned on prior to updating to 1.21?
Known Issues in 1.21
  • Global Settings > In/Outs > Guitar In Pad is not recalled after turning POD Go off and back on again. Unfortunately, this will need to be manually toggled after each power cycle before it begins working again
Using the effects loop or any additional pedals?  Go's signal is maybe too loud and causes one of your other pedals to clip.  Try lowering the volume of your amp in Go (ex; amp levels from 10 to 5 see if it clips less).
  • Thanks 1
Podgo into daw thats it I'm  hearing the clipping while playing  guitar
