ddufour Posted May 13, 2021 Share Posted May 13, 2021 Can you use the Spider editing software without a FVB Shortboard? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 13, 2021 Share Posted May 13, 2021 I’m not a Spider owner but I don’t see why not. Download it and try. Bad advice. Sorry. I didn’t realize the amp has no USB. Quote Link to comment Share on other sites More sharing options...
ddufour Posted May 13, 2021 Author Share Posted May 13, 2021 Not home to look at the amp but I don't know if there is a usb plug in the back or just a cat5 connection. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted May 13, 2021 Share Posted May 13, 2021 Just a CAT5, RJ45 modular jack. Didn't start using USB until the Spider V. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 14, 2021 Share Posted May 14, 2021 To be clear, do not plug the amp directly into your computer using a (what seems to be compatible) ethernet cable! To load patches to the Spider IV (and also to update the firmware in the amp), you need an FBV MkII pedal. Quote Link to comment Share on other sites More sharing options...
ddufour Posted May 15, 2021 Author Share Posted May 15, 2021 I just purchased a shortboard. Works fine changing patches, volume, wah, but when I plug in the usb and start the editing software the fvb does nothing. The software says I'm connected, but all it does is display some cc values. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 17, 2021 Share Posted May 17, 2021 To be clear, the FBV (must be MkII) is plugged into the computer via USB, and the amp to the FBV via the Cat5 cable right? The FBV just acts like an interface for the computer to talk to the amp. Quote Link to comment Share on other sites More sharing options...
ddufour Posted May 17, 2021 Author Share Posted May 17, 2021 All connections are correct. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 18, 2021 Share Posted May 18, 2021 Well, the FBV would not 'do anything' when you are using Spider Edit software. You create/edit/save patches in Spider Edit, then move them into the amp's User Patch locations. Quote Link to comment Share on other sites More sharing options...
Sison9357 Posted August 16, 2021 Share Posted August 16, 2021 When you set the FBV parameter to Vol=Glid, you'll have no volume control via the pedal, since it will be controlling Pitch Glide. MyCardStatement Quote Link to comment Share on other sites More sharing options...
