MissonHxC
Helix LT, channel switching and expression pedal
Hello everyone
I am the owner of a Helix LT that I use in 4CM mode with my amp head. I use the single EXT output to change the channel of my head.
When I change the channel via the helix, the light changes between EXP 1 and EXP2, so I had to assign two volume pedals at the beginning of the signal (one for each channel of the head).
But when I change snapshot (and head channel), pedal 2 goes to 0%.
I put a video that shows the problem.
It seems that this is only present on the LT since the original Helix has a dedicated output for the channel change.
Has anyone encountered this problem before?
Thanks a lot to all.
You should need only one Volume, Level and EXP PEDAL set to Snapshot control, then saved as required in EACH Snapshot.
  • Upvote 2
Thanks!
Your suggestion made me read the user manual. Turns out you can set the Exp 2 output to act only as an amp switcher.
So problem solved, I've now only one volume pedal and it works on whatever channel I am!
1 hour ago, MissonHxC said:
Thanks!
TBH, I wasn't really sure what the problem was, just took a shot. Glad you got it sorted!
