WillChiu
Looper with Command Centre
Hi, I'm using my HX Stomp with 3.11.0
While I was programming my looper with command centre, I found if I chose action as "Press/Hold" the looper actually triggers when on Release instead of Press.
Does anyone find themselves struggling with the same problem? I would love to use my "Press/Hold" but I can't even get the timing right because it's not on "Press".
That’s because there’s no way to differentiate whether you want the Press or the Hold function when you first press the footswitch otherwise. Have you tried using the Press/Release option instead?
