PodGo + DAW
OmegaSlayer
Hi
I connected the PodGo to the USB to record with Cubase
The device works as input, in fact I record the signal, with good quality, but the problem is that I don't have the guitar signal output from the monitors
It works for the rhythm parts, as you just have to be on the click, but for solos it's a problem, as you can't feel the expression
I could keep the cables connected to the amp, but the sound is too loud; If I play through the amp I have my presets output signals between -20db and -14db, and the amp volume at 0.5 (80W amp) but with the DAW I need to use at least -2db to have a decent signal
I have started recording with Cubase after 6 years, so I don't remember much about the connections
Is there something I'm overlooking?
