sloggy1962 Posted June 8, 2021 Share Posted June 8, 2021 Hello, have tried to change the tuning on my new variax jt59 and now the tuning knob is blue with the changed tuning, rest still white, How can I get the original tuning back to factory set? Complete factory reset with monkey6 failed. Thanks for answer, manual is not up to date upon this. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 8, 2021 Share Posted June 8, 2021 Re-Flash the Firmware through Monkey. Quote Link to comment Share on other sites More sharing options...
sloggy1962 Posted June 8, 2021 Author Share Posted June 8, 2021 Thanks, but this Re-Flash of the firmware failed, some midi error occured. Maybe because a Helix was routed in between. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 9, 2021 Share Posted June 9, 2021 If you have the interface accessory kit, then try using that to re-Flash. -Connect as you normally would. -Insert the charged up JTV battery into the battery box. -Plug a stereo 1/4" (TRS) headphone adapter into the 1/4" jack, listen for the click of the relay. -The interface device LED's should both be green. -Proceed with the update using Monkey. If that doesn't do it, then it should be checked out by an authorized service center in your area. Quote Link to comment Share on other sites More sharing options...
sloggy1962 Posted June 9, 2021 Author Share Posted June 9, 2021 Thank you, psarkissian, finally Re-Flash worked properly with interface accessory kit to laptop (without Helix). Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 9, 2021 Share Posted June 9, 2021 Awesome. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted June 9, 2021 Share Posted June 9, 2021 21 hours ago, sloggy1962 said: Hello, have tried to change the tuning on my new variax jt59 and now the tuning knob is blue with the changed tuning, rest still white, How can I get the original tuning back to factory set? Complete factory reset with monkey6 failed. Thanks for answer, manual is not up to date upon this. When you change the tuning on the tuning knob ex you change the Drop D with a Drop C on the knob , the Drop D will be blue light to remember you that this tuning is changed. it's not a default. If you want to get the White light again, just change the tuning with the original. This can be done with Workbench>tuning> manage Quote Link to comment Share on other sites More sharing options...
