tarming3 Posted June 10, 2021 Share Posted June 10, 2021 hi guys, any solution about the Pod Xt Live screen blank so suddenly !? i knew is about the firmware, but i can't sokve it with Windows 10 any body can help !? Quote Link to comment Share on other sites More sharing options...
unna Posted June 11, 2021 Share Posted June 11, 2021 14 hours ago, tarming3 said: hi guys, any solution about the Pod Xt Live screen blank so suddenly !? i knew is about the firmware, but i can't sokve it with Windows 10 any body can help !? Hi @tarming3. Why are you so sure that your problem is about the firmware? Quote Link to comment Share on other sites More sharing options...
daveny5 Posted June 12, 2021 Share Posted June 12, 2021 Q: How to resolve a blank screen on a PODxt LIVE A: If you are getting a blank screen on your PODxt LIVE please try the Edit Buffer Initialization with the following steps: 1. Turn off the POD 2. Turn on the POD while holding down the Save and Edit buttons simultaneously 3. The POD's LCD screen should display Init Edit Buffer 4. Push the Output mode button 5. Turn the Select / Select Page knob one click to the right 6. Turn the Effect Tweak / Change Value knob to the left or right adjusting the contrast. Quote Link to comment Share on other sites More sharing options...
