EVH Detune ala FU*K & Balance FX Settings: 4CM
JYD87
Trying to master the EVH detune sound with my LT.  I'm using the Helix as a pedalboard into my Splawn amp and real cabs doing 4CM, in place of my analogue pedalboard.  Before I get blasted for that, I paid $700 NEW for the unit, and I love my amps so it fits my needs perfectly when I gig.  I wanted to find a more flexible solution in an smaller pedalboard format and the price was great as are the features.
Upper path is into the front of my Splawn and my lower path is the my FX loop.  Right now I am using the Dual Pitch at -7/+7 on the Cents, VLevel is 9, Delay is 0, Mix is 50%, and it's right after the Wah in front of my amp.  I dig it, but it's a little more chorusy than Detune.  I read that I needed to add some delay to get it to be less chorusy.
I may have to try it going into my Loop.
We love to see how others are doing it.  I did find two youtube examples, one that I'm using, but I cannot find much info or suggestions in the forums!
Anyone else mastered the EVH detune in the Helix?
Cheers.
Here are the settings of a patch and clip on SoundCloud I did some time ago for another request by ear.
Dual Pitch Stereo
Interval 1: +0
Cents 1: +10.4
Delay 1: 13 ms
V1 Level: 10.0
Interval 2: +0
Cents 2: -11.2
Delay 2: 13 ms
V2 Level: 10.0
Mix: 38 %
Level: +3.0 dB
V1 Pan: Left 75
V2 Pan: Right 75
Dry Pan: Center
There obviously will be a difference when used mono.
Dual Pitch Stereo
Interval 1: +0
Cents 1: +10.4
Delay 1: 13 ms
V1 Level: 10.0
Interval 2: +0
Cents 2: -11.2
Delay 2: 13 ms
V2 Level: 10.0
Mix: 38 %
Level: +3.0 dB
V1 Pan: Left 75
V2 Pan: Right 75
Dry Pan: Center
Awesome, thank you.  I will try these settings in stereo.  I am currently using Mono.  Do you recall where you had this in your chain?  In front or in the FX loop/behind the amp block.
After amp, before cab. As you've hopefully seen I've linked the patch and clip.
You can inspect a patch directly here.
