minuitboulevard
Bonjour,
Je viens d'acquérir un POD HD500X et je n'arrive pas à avoir le même niveau sonore à la sortie des mes effets ce qui pose problème lorsque je joue et que je change de son.
Je me retrouve avec des sons avec un niveau sonore très faible et d'autre très fort.
Avez vous une idée simple pour pouvoir un niveau identique sur l'ensemble de mes presets ?
Merci beaucoup pour votre aide
Hello,
I just bought a POD HD500X and I can't get the same sound level at the output of my effects, which is a problem when I play and change sounds.
I find myself with some sounds with a very low sound level and others very loud.
Do you have a simple idea to have the same level on all my presets?
Thank you very much for your help
PianoGuyY's Guide to Volume Leveling
it is not simple. It is quite tedious. But it works.
And, the best part about it is - you only recently purchased your product. Which means you, if interested, can take advantage of it from the beginning and not have to redo 5 years worth of patches.
You might be interested in the volume leveling method I use, here follows the link to my post:
Volume leveling of different patches
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
On 6/19/2021 at 4:51 AM, minuitboulevard said:
Bonjour,
Merci pour ce retour, mais je n'ai pas compris ce que je dois faire.
Merci pour votre aide.
Cordialement
You didn't understand what to do because I didn't say what to do yet.
I was simply stating that there is a way - just not an easy way.
