looking for info on making your own IR's
kjbllc123
new to all this , I have cubase daw, I get the iimpression you can make your own ir"s looked at some utube stuff, but still seems kind of foggy on the basic idea or irs and how to make them. thank, I have the helix lt .  kevn
Do you have a mandolin and a violin each with electric pickup?
Then you would record both the pickup signal and a mic'ed signal at the same time. Then you would use a match eq plugin to match the pickup with the mic signal as source. If that then sounds good, you can use a deconvolver plugin to bake the eq into an ir.
