POD HD Pro Midi Toggle
SJenZip
Hi, I am trying to send MIDI commands to a POD HD Pro to toggle individual blocks on and off. Although I haven't connected a POD Footboard, I'm using another MIDI controller. When I send the CC message sometimes is works , sometimes is does. Do I need to send "0" for the off, and "127" for on? Do I need to send "127" repeatedly for toggle on and off states? I've trying lots of variations and am getting inconsitent behaviour.
Many thanks for any advise.
As can be deduced from the table above, to toggle (ie to change the current on/off status of) an effect assigned to a given footswitch the important thing is to send the right CC command number, and the assigned value can be any number between 0 and 127, it doesn't matter which.
Each time the device will receive the same CC command it will toggle the corresponding FS assignement on/off.
As another example , if we look again in the same table at the MIDI commands needed to control the Looper we see that to activate the RECORD function we must send the CC # 60 command with any value between 64 and 127, while to activate the OVERDUB function we must still send the command CC # 60 but this time with any value between 0 and 63.
All about POD HD500/X
help and useful tips
