Kenny202
Pod Go latency when using save / setting knobs
Looking at buying a used Pod Go. The guy seems to think there is a problem with the two control knobs (save and the one below) to select effects etc. For eg switch to the right and every now and then it doesn't select but click again then jumps two places. Is this simply a memory delay from switching too fast or could well be a fault? I would be surprised if there was a fault with upper and lower knobs
https://photos.google.com/share/AF1QipPG8szSlUGQj81e_GFv2WJFGQPt48yTc-L10VQveplcQtdn8sxcuT1yT2m95QVuXw?key=RDlaUHdFVUtoV0RnVmlFRFVZMHpXRmFMTktJcWJR
https://photos.google.com/share/AF1QipPJwIVFZzp4C-bOJYncCSG8_fdasaqQsPs5E9anNtr-LOgkQxj4T_qjnS_hXjlsIg?key=UWtxbDdzaE9hZl9JdkhDRjJ1bVNYRDFQQk1TRGtB
By the way can the pod Go be simply used as a pedal board where I can select or unselect 4 individual pedals rather than preset banks? Eg Select A...Distortion   B....Delay   C....Chorus etc
Not serious at all, all Pod Gos have this. I suspect it's just a minor software bug...I've again flagged to Line 6 support.
Yeah, there's a snapshot mode when each 'patch' can have 4 'snapshots'.  Basically, there's a delay where the sound cuts off when switching patches, but no delay/cut when switching snapshots, and with each snapshot you can change settings on multiple pedals/amps/etc., so for using live without cuts in sound, people tend to use snapshots.
The mode you're describing is pretty much default mode, where the 6 footswitch buttons can all be assigned to 1 effect and can turn it on/off, with a colored light indicating if the effect is on/off.  So compresser on/off, reverb1 on/off, distortion pedal on/off, FX Loop on/off, etc.
