Tboneous Posted June 30, 2021 Share Posted June 30, 2021 Hello All, I have a Helix Floor and 2 PC+. In Helix edit, I would like to have one amp model on the top stereo path and one amp model on the second stereo path. I want the top amp model to come out of my left PC+ and the bottom amp model to come out of the right PC+. I can’t for the life of me figure out how to do this? I am using L6 link. any help is much appreciated T Quote Link to comment Share on other sites More sharing options...
waymda Posted June 30, 2021 Share Posted June 30, 2021 Try this as a starting point (feel free to change EVERYTHING as this is just a starting template I use). Its intended to have a seperate amp each side and full cabs etc through the XLRs and I use it with PC+ using the digital out for speaker models and/or FRFR depending on use. For the PC+ you will need to change the line output to digital and then you can control the cabs iseperately as I uploaded it for someone wanting to send outputs to a JC120. https://line6.com/customtone/tone/5478251/ Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 30, 2021 Share Posted June 30, 2021 This will depend on which PC+ model you're using, 112 or 212. Since you specified using two stereo paths, I assume you have two PC212+ cabs, else you don't need separate stereo paths. Using L6 Link, you may have a problem, since, IIRC, there's a bug when using two PC212+ cabs. Sorry, I don't remember the details. In either case, in theory, when you connect L6 Link from Helix to Cab 1 and Cab 1 to Cab 2 (via L6 Link), by default Cab 1 is configured as LEFT and Cab 2 is configured as RIGHT. In your preset, have separate Output Blocks for each amp path. Pan one LEFT and the other RIGHT. Since I only have a single PC212+, I can't personally attest to how well this works and, as mentioned, I don't recall the details of the bug. Let me know how it turns out. Quote Link to comment Share on other sites More sharing options...
Tboneous Posted August 10, 2021 Author Share Posted August 10, 2021 Thanx! Quote Link to comment Share on other sites More sharing options...
