willyjacksonjs22 Posted July 7, 2021 Share Posted July 7, 2021 Anyone here adds a room reverb effect after the chain to give an amp room sound/effect when recording? I watched a video long time ago where it explains the settings but i cant find it. anyone wanna share? Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted July 7, 2021 Share Posted July 7, 2021 You'll have much more success if you learn about it on your own. Just go to each setting and adjust them one at a time all the way up and then all the way down so you can hear and learn what each parameter does. Do that on each one a few times so you understand what's happening. Once you have that sorted out in your mind, adjust to your own taste. 1 2 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 7, 2021 Share Posted July 7, 2021 Experiment! There are no magic settings that work in all circumstances. Use the LOOPER as the first block and record a short guitar bit, Then fiddle around with the reverb parameters - especially with PREDELAY which can change how the guitar sounds due to phase interaction in the 0-40ms range. 1 1 Quote Link to comment Share on other sites More sharing options...
mritt Posted July 7, 2021 Share Posted July 7, 2021 Mix a little "Tile Verb" in there also - either before, or in parallel to the "Room Verb". A little goes a long way. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 8, 2021 Share Posted July 8, 2021 There are no magic, one-size-fits-all reverb parameters. Even if you're trying to recreate a sound ultra-specific to a certain tune, achieving it will depend largely on what you're listening through...headphones, studio monitors, etc etc. With the latter, if you're in a particularly "live" room with lots of natural reflections, you'll need far less reverb than if you're listening in a dead, carpeted room with a big fluffy couch, or monitoring with headphones. Just start fiddling with the parameters of whatever reverb you've chosen, and get used to what each setting does. "Knobulate" to taste... 1 1 Quote Link to comment Share on other sites More sharing options...
kylotan Posted July 11, 2021 Share Posted July 11, 2021 I find that almost any non-exotic reverb (i.e. not octo, particle, etc) does wonders for this, providing you keep the mix low - somewhere between 3% and 10% according to taste. Quote Link to comment Share on other sites More sharing options...
