JukeLones
Loop pedal effects help needed
So I’m trying to change effects when starting a new layer of the loop, but every time I add an effect it applies to the playback loop already recorded. Is there a way to avoid this? I feel like I see people online using different effects simultaneously on different layers but none have explained how. Thank you in advance for any help!
Yeah, just place the looper block at the complete end of your chain!  As any effect which is after the looper, as you said, will affect the looper block looping your recorded sound!
  • Thanks 1
Thank you so much!! Feel so silly that it was that easy. You’re a life saver. Appreciate the help.
Welcome!  :D
You might also want to read this thread!
