sarang7158 Posted July 23, 2021 Share Posted July 23, 2021 I bought hx stomp 2week ago. with midi controller it's just best multi pedal what i've ever used Now I need external pedal and switch and i'll buy dvp4 expression pedal for whammy or wha but here is problem someone says I have to use trs-ts cable for hx stomp, and someone says i can use trs-trs too (he says in trs-trs case, setting has to be chaged) what i have to use for expression cable? trs-ts or trs-trs? and another question some cable has trs - ts,ts (so.. it has 2 output) in this case, if I connect expression pedal and external footswitch each one, is it work together?? plz reply to help for me Quote Link to comment Share on other sites More sharing options...
ossianott Posted July 23, 2021 Share Posted July 23, 2021 I'm using a cable like this: https://m.thomann.de/se/pro_snake_tpy_2003_jbb.htm?o=15&search=1627023221 Successfully connecting the m-audio ex-p plus a foot switch to the stomp (exp4/fs5). The ex-p is TRS out. IIRC both TRS and ts work as cable for the footswitch. I can also connect the ex-p directly to the input without the y cable, but IIRC it only works with exp4 not exp5 that way. As the Y cable is dual TS female I think it is forgiving in regards of TRS or TS cable. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 23, 2021 Share Posted July 23, 2021 4 hours ago, sarang7158 said: some cable has trs - ts,ts (so.. it has 2 output) in this case, if I connect expression pedal and external footswitch each one, is it work together? Yes. Quote Link to comment Share on other sites More sharing options...
