requietus666
stomp xl tempo blink AND tuner
hi,
under stomp xl global settings you can either use tap/tuner or all-bypass on the dedicated footswitch.
is there an option (or workaround) to have the blinking LED to be off and to be able to access tuner (as it can be done on hx floor) ?
Yes. Global Settings>Displays>Tap LED.
has the dev team of an option to make it other way around so that tap tempo isn't active at all, eg, tap - tuner, long press - bypass (switchable) ? m ?
