Sign in to follow this
jnthnkslbch
Update from 2.3 (!), please help
Hi guys, my Helix currently still has the 2.3 firmware and since I have never used the HX Edit, I wanted to start with it. Now I see that you have to be careful when updating, otherwise you can break a lot. (from 2.7 to 2.8 e.g.) My question is how best to update from this old version. Is it enough to make a backup before and update to 3.1 right away? Or should I take smaller steps with the critical firmware change, from 2.3 to 2.7, then from 2.7 to 2.8 and then from 2.8 to 3.1? I don't really have a clue and would be happy if someone could give me advice.
Thank you!
Here’s the best advice you can get - direct from Line 6 firmware update release notes. Just follow the instructions.
Take note as mentioned in the release notes that as you are updating from such a low version - the software will appear to update twice. This is normal and I had the same as also updated directly from 2.3.
But the software is good at guiding you through the process.
