1/4" outputs to aux in - line or instrument?
bingefeller
For now I'm running my Helix into the "aux in" of my Boss Katana Air.
Do I set the 1/4" outputs to "line" or leave them as instrument?  I've found conflicting information on this at various other places, so thought I would come here to get a definitive answer.
Thanks!
probably does not matter too much....it's most likely 1:1, high impedance buffer like the LS2...I've hit them with both ways...Line is usually better when available as you tend to get a lower noise floor....An LS-2 has a trim to match up to instrument...not sure what that thing has, but Boss does buffers pretty well...try both, pick the best sounding one...most likely Line Level.
  • Thanks 1
You could have gone to Boss and checked out the spec for the correct answer.
Katana Air Aux In is specified as -10dBu on a stereo mini jack.
Also, using headphones out is just wrong.
Hope this helps/makes sense.
