bingefeller Posted August 20, 2021 Share Posted August 20, 2021 For now I'm running my Helix into the "aux in" of my Boss Katana Air. Do I set the 1/4" outputs to "line" or leave them as instrument? I've found conflicting information on this at various other places, so thought I would come here to get a definitive answer. Thanks! Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted August 20, 2021 Share Posted August 20, 2021 Set the Helix Outputs you are using to Line. The Aux In of your Boss Katana Air is very likely expecting a line level signal, rather than an instrument level signal. 1 Quote Link to comment Share on other sites More sharing options...
spaceatl Posted August 20, 2021 Share Posted August 20, 2021 probably does not matter too much....it's most likely 1:1, high impedance buffer like the LS2...I've hit them with both ways...Line is usually better when available as you tend to get a lower noise floor....An LS-2 has a trim to match up to instrument...not sure what that thing has, but Boss does buffers pretty well...try both, pick the best sounding one...most likely Line Level. 1 1 Quote Link to comment Share on other sites More sharing options...
bingefeller Posted August 20, 2021 Author Share Posted August 20, 2021 Thank you @MusicLaw and @spaceatl. best wishes. 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted August 20, 2021 Share Posted August 20, 2021 @bingefeller, do post your findings. 1 Quote Link to comment Share on other sites More sharing options...
bingefeller Posted August 21, 2021 Author Share Posted August 21, 2021 13 hours ago, MusicLaw said: @bingefeller, do post your findings. Well I tried it this morning. The instrument level is lower than when I select line level. I tried going headphones out into the aux in, and selecting line level and instrument level made no difference. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted August 23, 2021 Share Posted August 23, 2021 Line and Level output selections do not directly affect the headphones level output. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted August 24, 2021 Share Posted August 24, 2021 Like all questions of this nature, do some reading. Find out what for certain your Katana wants to see at the Aux Input and set it to that. Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 24, 2021 Share Posted August 24, 2021 On 8/20/2021 at 8:43 PM, bingefeller said: thought I would come here to get a definitive answer. You could have gone to Boss and checked out the spec for the correct answer. Katana Air Aux In is specified as -10dBu on a stereo mini jack. Also, using headphones out is just wrong. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
