linea06 0 Posted March 5, 2014 Hey guyz just wondering if i use the 500x in pedalboard mode can i still bank up and down with different pedal settings.. Kinda like the m13 that has scenes.but i still want to use the amp models .. Ex. Bank 1 Fender amp with whatever 8 effects i choose.. Bank 2 Dr.z amp with another set of effects......and so on... Quote Share this post Link to post Share on other sites
silverhead 8,809 Posted March 5, 2014 The Up/Down footswitches work differently depending on your global FS Mode setting. In FS Mode = ABCD the switches move you up or down one bank at a time, and the A through D switches select the preset within the current bank. In FS Mode = FS5-8 the switches move you up or down one preset at a time, not one bank at a time. Quote Share this post Link to post Share on other sites
linea06 0 Posted March 5, 2014 The Up/Down footswitches work differently depending on your global FS Mode setting. In FS Mode = ABCD the switches move you up or down one bank at a time, and the A through D switches select the preset within the current bank. In FS Mode = FS5-8 the switches move you up or down one preset at a time, not one bank at a time.So it is possible... Just 1 preset at a time..So instead of bank it would be Preset 1 fender amp with 8 effects..(pressing the bank up = 1 preset up) Preset 2 dr.z amp with different effects.. Is that correct???? Quote Share this post Link to post Share on other sites
silverhead 8,809 Posted March 5, 2014 Oops........ My bad. Sorry for the misinformation. Thanks for the correction hurghanico. Quote Share this post Link to post Share on other sites
linea06 0 Posted March 5, 2014 Sorry man.. but the above information isn't correct.. I use the FS 5-8 mode all the time and the Up/Down footswitches change one bank at a time (not the preset) the main difference when using the FS 5-8 mode is that every time you want change preset you need always a double press.. by pressing the up or down footswitch enters the "change bank/preset" mode and let you change bank (if you want), after that you have to press one of the FS 5-8 (which become active momentarily as ABCD preset switches) to choose which of the 4 presets into the bank you want, and to exit the "change bank/preset" mode Kool I give it a shot!!! THANKS !!!! Quote Share this post Link to post Share on other sites
