David1an Posted August 28, 2021 Share Posted August 28, 2021 I have recently purchased a Pod Go with the intention of using it with my Marshall JVM 410 in the 4 cable method into the effects loop. I want to be able to use my amps gain tones as well as put effects in front and behind my amp. I have watched a few You Tube video's on how to do it but it only seems to work ok on the clean channel. The JVM has 4 channels with 3 modes on each channel and as I progress through the higher gain channels and modes, the hum/buzz gets louder and louder to the point that it is louder than the sound coming from the guitar. I have tried making adjustments in the global settings and on the back of the amp with no success. I was in the process of putting together a pedal board but the thought the Pod go might be an easier option and for this reason I brought it. I still need to run some pedals through the effects loop to make sure there isn't a problem there but I was wondering if anyone else has had this problem and/or knows of any solution. Cheers Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 29, 2021 Share Posted August 29, 2021 1. Pod Go forum dataway ==> 2. Yes, higher gain stages result in higher fuzz/hiss/hum type noises. Assuming it isn't normal noise that we all hear, could this be a ground loop or shielding issue? Quote Link to comment Share on other sites More sharing options...
