Punkyboy Posted September 1, 2021 Share Posted September 1, 2021 Hello I'm new to Helix Is there a easy way to delete a snapshot ex: there is 4snapshots nad I want to delete the snapshot 3 Tx Quote Link to comment Share on other sites More sharing options...
datacommando Posted September 1, 2021 Share Posted September 1, 2021 13 minutes ago, Punkyboy said: Is there a easy way to delete a snapshot Hi, Nope, not really a way to delete a Snapshot as such, but if you are in HX Edit you could simply copy a blank Snapshot and paste it over the one you don't want, then rename the one you want to get rid of. For example: if Snapshot 4 is not used, select and copy it. Then select Snapshot 3 (the one you want to get rid of) and paste the copy of 4. Now rename it to Snapshot 3. Hope this helps makes sense. Quote Link to comment Share on other sites More sharing options...
theElevators Posted September 1, 2021 Share Posted September 1, 2021 Let me explain how I use snapshots. I use a different preset for each song. If there are some sections in a specific song, for example only 2 (rhythm and solo), then I create 7 identical snapshots with blank scribble strip texts, and one that says "SOLO". If there is a song that uses one sound throughout, I just have 8 identical snapshots that have blank text. There's no way to delete a snapshot, you can just choose which ones do what. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted September 1, 2021 Share Posted September 1, 2021 I do the same thing with a preset/song thing. Some songs have 1 snapshot, some have 5 or 6. I've never used 8 snapshots. What I do for my extra snapshot slots is make those my main rhythm sounds so if something happens its not my lead or clean sound that makes a huge dynamic difference. I copy and paste that snapshot to all non-used slots, and then for the name, I enter a blank space so no name appears. I also do not assign a color to it. I run my layout in the 10 button stomp mode in this format.... Buttons 1 & 2 are my Preset Previous/Next Bottom row buttons (5 available) I have dedicated for snapshots, I start from the right and work left, so if I have 5 snapshots the one next to the BPM switch is my snapshot 5 and I work left. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted September 1, 2021 Author Share Posted September 1, 2021 Ok thank you guy's ! I did what datacommando say, but i tough it was a better than this copy/paste 1 Quote Link to comment Share on other sites More sharing options...
