loydall Posted September 5, 2021 Share Posted September 5, 2021 Hi, do any of you have recommendations for a stereo power amp I can run my hx stomp through? The only one I've found that looks suitable is the Powerstage 700. I was thinking of running 2 separate pedalboard power amps for stereo but I think 1 single uint would be easier. Any suggestions? Cheers. Quote Link to comment Share on other sites More sharing options...
waymda Posted September 5, 2021 Share Posted September 5, 2021 The only one I've found that looks suitable is the Powerstage 700. Suggests you have some criteria/requirements - you might want to share those if you want sensible input. Quote Link to comment Share on other sites More sharing options...
loydall Posted September 5, 2021 Author Share Posted September 5, 2021 12 minutes ago, waymda said: The only one I've found that looks suitable is the Powerstage 700. Suggests you have some criteria/requirements - you might want to share those if you want sensible input. Well - the power stage 700 is probably more than powerful enough for my needs. I'd be looking to hook it up to 2 1x12's. I like running amps/preamps in my helix into the fx return of amps I've had to the point that I rarely use the real amp's preamp stage. I'm looking for stuff that's easy to carry (I have a bad hip) so anything that could sit on my pedalboard would be great but I'm not against a small unit/head that could sit on one of the 1x12s. Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted September 5, 2021 Share Posted September 5, 2021 Have you considered a lower output public address amplifier? Crown has some affordable models, like the XLi line for example. Quote Link to comment Share on other sites More sharing options...
Espexp Posted September 5, 2021 Share Posted September 5, 2021 I am using an ISP stealth. It is a very clean transparent power amp bridged into a Mission Gemini passive 1x12 frfr speaker. I plan to get a second 1x12 to run stereo. Quote Link to comment Share on other sites More sharing options...
